Vellum straps help
Jag80
I have a pump connected with a strap that is hanging from a pole.  The pump is animated to fall and I want the strap to break and spring over the pipe as it falls.  I have boolean on the strap where I want it to break with vellum weld constraints and that separates fine.  I messed around with rest length and made it shorter to give that spring back motion I looking for, but that kind of messes up the other end as well and it stretches it too much.  Is there a way to make the strap go over the pole and retain shape and to also stay hooked to the loops on impact? They totally disconnect when it hits the floor. Any help would be great. Thanks.
Strap_Break.hiplc
