Solver vector directions comparison problem
Jsmidlow
Hello. I'm struggling with changing vector direction inside a solver. In the file attached there is a point that reads vector attribute of a nearpoint and uses it in order keep on moving. The movement is done in solver. The problem is that it can after doing a "step" the point can take a new vector that is opposite to it's current direction and "step back". It returns to previous position where it gets a former "go ahead" vector and does a "step forward" and repeats the whole vector change and "back and forth" movement on and on. Inside the solver I try to compare vectors of previous and current frame and build a condition - if they are opposite let the point go down {0,1,0}; But no matter how I try it doesn't work.
If someone can help me...
SOLVER_problem.hipncFetching info...
Edited by Jsmidlow
