MADjestic Posted December 4, 2006 Share Posted December 4, 2006 Hi there, is it possible to run DOPs simulation with proxy geo and then substitute the lowpoly geometry with high-poly geometry? Basically (in theory) all we need is to get the transformation of an object and pipe its' transform params into new arbitrary geo. Is there a simple way to do this? Thanks. Quote Link to comment Share on other sites More sharing options...
Visual Cortex Lab Posted December 4, 2006 Share Posted December 4, 2006 here's a simple scene I did long time ago for the same purpose... hope this helps.. and hope this is a correct way to do this... cheers _DOP_chairs_1.hipnc.tar.gz Quote Link to comment Share on other sites More sharing options...
MADjestic Posted December 4, 2006 Author Share Posted December 4, 2006 [one' date=Dec 4 2006, 02:03 AM' post='32440]here's a simple scene I did long time ago for the same purpose... hope this helps.. and hope this is a correct way to do this... cheers Thanks sum][one, however I am afraid I didn't express myslef clear enough. Ideally I would like to use the result of the DOPs simulation with proxy geo for highpoly geo - i.e. there are cases when one can be satisfied with the proxy geo precision simulation, but would like to simply substitute the proxy geo with the highpoly geo for 'final rendering' - thus _not _ rerunning the simulation again. P.S. sorry,sum][one forget my reply - this is really what I need- it's just my buggy windows box where I tryied your example - the refreshment time with the chair animation made me think that the simulation is actually rerun, hehe. Thanks! Quote Link to comment Share on other sites More sharing options...
Visual Cortex Lab Posted December 4, 2006 Share Posted December 4, 2006 eheheh I was actually checking my scene again once i started reading your answer... ... glad you found it usefull... as i said.. this is an old scene.... and I'd make it in a different way now maybe... but that was a "fast reply" to your question and I'm happy it helped you out. cheers. p.s. DOP is the part of houdini i know the least ... I need to check that Gnomon DOP DVD out soon .. Quote Link to comment Share on other sites More sharing options...
B.Walters Posted December 6, 2006 Share Posted December 6, 2006 #17 in the DOPs FAQ has an example of that (17-fetch.hip if I'm not mistaken)... there are several conceivable ways to do this - so let me know if you want an example of another way and I'll work up a quick scene. http://www.sidefx.com/exchange/info.php?fi...p;versionid=327 Quote Link to comment Share on other sites More sharing options...
