william-or Posted March 7, 2021 Share Posted March 7, 2021 Hi everyone I'm kinda new to houdini and I've recently started playing with the Solver SOP, but I don't really understand how the geometry is processed inside the solver. Essentially if I try to move some points through a solver, what I see inside of it is a static mesh that moves its points but that doesn't really shifts (as if on every frame the points are set to 0 and then moved again) but if I look at the Geometry (one step above) viewport everything works as it should. Can also anyone help understand "dop import" node and how it works in the solver. Any help is appreciated. test_solver.hipnc Quote Link to comment Share on other sites More sharing options...
