gundan44 Posted March 15, 2021 Share Posted March 15, 2021 Hello everyone, I have a pretty basic problem cant be solved. In some situation, I need to put water in some kinda ice basket which is moving pretty fast and throw out the water inside of it. But when I create the scene, I found that whatever I try, fluid in the basket will not move with the collider because it is moving too far from frame to frame. I try to increase substeps to 5 but nothing really change. What other parameter or set up can I try to solve this situation? or any other idea to cheat in this scene? Any idea will be very appreciate. Quote Link to comment Share on other sites More sharing options...
squardis Posted March 16, 2021 Share Posted March 16, 2021 make your container thick on the outisde may help you. I have a simular problem, but this should normally be doing the job without increasing substeps: Quote Link to comment Share on other sites More sharing options...
