catchyid Posted March 16, 2021 Share Posted March 16, 2021 hi, houdini 17.5, linux, python 2.7 (the version that ships with houdini :)) i want to launch a hython script in a shell (e.g. xterm) and show its progress to end user (basically, I need to show to artist the progress of this script, also, I want this xterm to be independent of houdini, meaning, if the user shuts down houdini, i want xterm to be running and finishe the job). I am new to python, so I checked quickly and found a way to use subprocess.Popen(['xterm'],stdout=PIPE,stderr=PIPE) which starts a shell, but could not find anyway to send the command (e.g. my hython script) to the shell (tried process.communicate, ...but nothing worked!) I am thinking, maybe there is another ready to use gui/API in houdini to allow that? note: i don't want to use "run in the background" in file cache node because I need to run a script, plus i might run multiple instances of the same script (each one is doing processing different part of the hip file, it's all done on the fly, so I don't even know how many file cache node I need) Thx Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted March 16, 2021 Share Posted March 16, 2021 # myscript.py import os import time for f in os.listdir("."): time.sleep(0.1) print(f) From Houdini: import subprocess # Note the -u flag for unbuffered output cmd = "xterm -hold -e 'hython -u myscript.py'" proc = subprocess.Popen(cmd, shell=True) 1 Quote Link to comment Share on other sites More sharing options...
catchyid Posted March 16, 2021 Author Share Posted March 16, 2021 what can I say , thank you is not enough , really appreciate your help thx Quote Link to comment Share on other sites More sharing options...
