hindukush Posted March 21, 2021 Share Posted March 21, 2021 Hi everybody, i'm facing issues orienting Arnold lights copy to points normal.I'm actually using this .hda (https://www.artstation.com/artwork/zA3BVd) But no chance to get orientation.I should get the point normal and convert to degrees for the light. Can anybody point me in the right direction? Anyone knows a better way to copy arnold lights to points? Thank you sooo much! Carlo The python script that is used is : from math import sqrt def destroyInstance(kwargs): # Define Variable node = kwargs['node'] try: scatterNodePath = node.parm('scatterPath').eval() scatterNode = hou.node(scatterNodePath) scatterGeo = scatterNode.geometry() except: hou.ui.displayMessage('I can\'t find the scatter node "' + scatterNodePath + '" !') exit() scatterNodePath = node.parm('scatterPath').eval() scatterNode = hou.node(scatterNodePath) scatterGeo = scatterNode.geometry() instanceName = node.parm('instanceName').eval() # Instance Loop try: for pt in scatterGeo.points(): nameInstance = instanceName + '_' + str(pt.number()) instances = hou.node('/obj/' + nameInstance) instances.destroy() hou.item('/obj/networkInst').destroy() hou.item('/obj/networkMain').destroy() except: pass def createInstance(kwargs): node = kwargs['node'] # Define Variable try: scatterNodePath = node.parm('scatterPath').eval() scatterNode = hou.node(scatterNodePath) scatterGeo = scatterNode.geometry() except: hou.ui.displayMessage('I can\'t find the scatter node "' + scatterNodePath + '" !') exit() try: instanceNodeName = node.parm('nameNode').eval() test = hou.node('/obj/').createNode(instanceNodeName, "test") test.destroy() except: hou.ui.displayMessage('The name of node "' + instanceNodeName + '" doesn\'t exist ! ') exit() linkPosPts = node.parm('linkPosPts').eval() instanceName = node.parm('instanceName').eval() linkAttribPt = node.parm('linkAttribPt').eval().split() copyPtAttribValue = node.parm('copyPtAttribValue').eval().split() linkParmFirstInstance = node.parm('linkParmFirstInstance').eval().split() revertParmValue = node.parm('revertParmValue').eval().split() parmList = revertParmValue + linkParmFirstInstance + copyPtAttribValue +linkAttribPt attribList = linkAttribPt + copyPtAttribValue # Instance Loop for pt in scatterGeo.points(): # Create Light nameInstance = instanceName + '_' + str(pt.number()) try: test = hou.node('/obj/' + nameInstance).name() networkBoxMain = hou.node('/obj/' + 'networkMain') instances = hou.node('/obj/' + nameInstance) firstRun = 0 except: # Create Node firstRun = 1 instances = hou.node('/obj/').createNode(instanceNodeName, nameInstance) #TEST if nameInstance == instanceName + '_0': for p in parmList: try: instances.parm(p).eval() except: hou.ui.displayMessage('The parameter "' + p + '" doesn\'t exit !') if(firstRun == 1): instances.destroy() exit() for a in attribList: try: pt.attribValue(a) except: hou.ui.displayMessage('The Attribut "' + a + '" doesn\'t exit !') if(firstRun == 1): instances.destroy() exit() # Position Light if linkPosPts == 1: instances.parm('tx').setExpression('point("' + scatterNodePath + '", ' + str(pt.number()) + ', "' + 'P' + '", 0)') instances.parm('ty').setExpression('point("' + scatterNodePath + '", ' + str(pt.number()) + ', "' + 'P' + '", 1)') instances.parm('tz').setExpression('point("' + scatterNodePath + '", ' + str(pt.number()) + ', "' + 'P' + '", 2)') else : instances.parm('tx').deleteAllKeyframes() instances.parm('tx').set(pt.position()[0]) instances.parm('ty').deleteAllKeyframes() instances.parm('ty').set(pt.position()[1]) instances.parm('tz').deleteAllKeyframes() instances.parm('tz').set(pt.position()[2]) # Revert parm value to default value for rpv in revertParmValue: instances.parm(rpv).deleteAllKeyframes() instances.parm(rpv).revertToDefaults() # Copy Points Value in Paramaters for cap in copyPtAttribValue: instances.parm(cap).deleteAllKeyframes() instances.parm(cap).set(pt.attribValue(cap)) # Link Points Value in Paramaters for lap in linkAttribPt: type = scatterGeo.findPointAttrib(lap).dataType() if str(type) == "attribData.String" : print(type) instances.parm(lap).setExpression('points("' + scatterNodePath + '", ' + str(pt.number()) + ', "' + lap + '")') else : instances.parm(lap).setExpression('point("' + scatterNodePath + '", ' + str(pt.number()) + ', "' + lap + '", 0)') if pt.number() == 0 : # Color Node instances.setColor(hou.Color((1.0, 0.72, 0))) else : instances.setColor(hou.Color((1, 0.98, 0.67))) # Link Paramaters To First Instance's paramaters for lpfi in linkParmFirstInstance: instances.parm(lpfi).setExpression('chs("/obj/' + instanceName + '_0/' + lpfi + '")') # NetworkBox networkBoxMain = hou.item('/obj/networkMain') networkBoxInst = hou.item('/obj/networkInst') try: if networkBoxMain.comment() == instanceName: networkBoxMain.destroy(False) except: pass try: if networkBoxInst.comment() == (instanceName + "_Instance"): networkBoxInst.destroy(False) except: pass networkBoxMain = hou.node('/obj/').createNetworkBox('networkMain') networkBoxMain.setComment(instanceName) networkBoxMain.setColor(hou.Color((0.98, 0.78, 0.26))) networkBoxMain.setMinimized(1) networkBoxInst = hou.node('/obj/').createNetworkBox('networkInst') networkBoxInst.setComment(instanceName + "_Instance") networkBoxInst.setColor(hou.Color((1, 0.98, 0.67))) networkBoxInst.setMinimized(1) col = round(sqrt(len(scatterGeo.points()))) for pt in scatterGeo.points(): nameInstance = instanceName + '_' + str(pt.number()) i = pt.number() node = hou.node('/obj/' + instanceName + '_' + str(i)) if i == 0: node.setPosition([.2, .8]) networkBoxMain.addItem(node) networkBoxMain.addNetworkBox(networkBoxInst) else : networkBoxInst.addItem(node) tmpPos = [i%col*3, round((col*col-i / col)-.5)] node.setPosition(tmpPos) networkBoxInst.resize([1, 1]) networkBoxInst.setPosition([1.5, 0]) networkBoxMain.resize([1, 1]) tmpPos = scatterNode.parent().position() tmpPos[0] += 4 networkBoxMain.setPosition(tmpPos) networkBoxMain.setMinimized(0) Quote Link to comment Share on other sites More sharing options...
hindukush Posted March 21, 2021 Author Share Posted March 21, 2021 Maibe adding something like this? dirx: euler = hou.parmTuple("r").eval() dir = hou.Vector3((0,1,0)) * hou.hmath.buildRotate(euler) return dir[0] diry: euler = hou.parmTuple("r").eval() dir = hou.Vector3((0,1,0)) * hou.hmath.buildRotate(euler) return dir[1] dirz: euler = hou.parmTuple("r").eval() dir = hou.Vector3((0,1,0)) * hou.hmath.buildRotate(euler) return dir[2] Quote Link to comment Share on other sites More sharing options...
