5DNick Posted April 4, 2021 Share Posted April 4, 2021 Dear ODForce people, I've fed a frame from a pyro sim I did into another sim to be the initial data. I then run that and cached it but it seems to still contain the initial data frame. I've attached .hiplc file but not cache files. Can you see or do you know the problem? Do I NEED to upload the cache files too? Cheers Nick SLOMOPYROexplode05.hiplc Quote Link to comment Share on other sites More sharing options...
bunker Posted April 4, 2021 Share Posted April 4, 2021 1) you need to separate the initial data fields, eg: Density SOP Path is expecting density only 2) your volumesource SOP Path, is set to the initial_data, instead you need a volume source (retimed for slowmo) Quote Link to comment Share on other sites More sharing options...
5DNick Posted April 5, 2021 Author Share Posted April 5, 2021 So I've blasted in three different streams eg. not @name=density etc. and specificed those in the smoke object. Is that correct? Then I'm feeding a convertvdb (converting to volume) into volume source SOP path. Is that correct? I'm not sure what you mean retimed for slowmo? A retime node? Don't know how to use that but will look into it if correct Thanks for the help Quote Link to comment Share on other sites More sharing options...
5DNick Posted April 5, 2021 Author Share Posted April 5, 2021 OK that problem seems to be fixed (without retime node) However there is also a problem at rendertime. emission seems to be small at beginning and rise fast to levels which overexpose cam. is there an obvious reason for this (error i made) ?? i'm using redshift and dont really wanna keyframe emission. plus redshift pyro seems to need a delicate balance of scatter absorption AND emission so this might be too hard NB: my redshift setup is fine with normal pyro (like the first sim in the .hiplc file in the OP) thanks for the help PS: i'm a happy bunny atm cos i feel like I'm actually learning Houdini whereas before I always felt out of my depth Quote Link to comment Share on other sites More sharing options...
5DNick Posted April 5, 2021 Author Share Posted April 5, 2021 here is short clip shadingproblem.mp4 Quote Link to comment Share on other sites More sharing options...
bunker Posted April 5, 2021 Share Posted April 5, 2021 that looks like a sim issue, not shading. can you upload your latest scene? Quote Link to comment Share on other sites More sharing options...
5DNick Posted April 6, 2021 Author Share Posted April 6, 2021 oh ok. here: SLOMOPYROexplode07.hiplc Quote Link to comment Share on other sites More sharing options...
bunker Posted April 6, 2021 Share Posted April 6, 2021 (edited) you were mixing sparse pyro and old pyro solver, completely different solvers you should have a look at this thread: in your case, you can just plug the result of the last frame into a new sim using the SOP pyrosolver (sparse), and copy the fields with the "copy" operation on frame 1: note that I copy flame>flame instead of burn>flame since it doesn't exist in the cached sim. hope that makes sense. SLOMOPYROexplode07b.hiplc PS: creating slowmo explosions isn't easy, have fun Edited April 6, 2021 by bunker Quote Link to comment Share on other sites More sharing options...
5DNick Posted April 6, 2021 Author Share Posted April 6, 2021 Thanks alot bunker. Yh i bet its not easy!!!!! I always dive in the deep end with my projects, even if they don't get finished sadly! BUT NOT THIS TIME!!!!!! Quote Link to comment Share on other sites More sharing options...
5DNick Posted April 7, 2021 Author Share Posted April 7, 2021 cool. i see what you did. thanks. so i am going to proceed by siming 50 sub frames and then putting these into the normal frame time range right? not entirely sure how to do this but going to look into it this is the way to do it isn't it? i understand timescale breaks the physics equations under the hood? navier-stokes? i'm intermediate at maths. Quote Link to comment Share on other sites More sharing options...
5DNick Posted April 7, 2021 Author Share Posted April 7, 2021 getting this error now: Traceback (most recent call last): File "Sop/filecache/execute", line 1, in <module> File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.462/houdini/python3.7libs\houpythonportion\ui.py", line 1081, in decorator return func(*args, **kwargs) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.462/houdini/python3.7libs\hou.py", line 69068, in render return _hou.RopNode_render(self, *args, **kwargs) hou.OperationFailed: The attempted operation failed. Error: Cook error in input: /obj/explosion/filecache2/cast_attributes Error: Invalid source /obj/explosion/pyrosolver2/dopimportfield1/load_each_field_end Error: The sub-network output operator failed to cook: /obj/explosion/pyrosolver2/dopimportfield1/switch3 Error: Invalid source /obj/explosion/pyrosolver2/dopimportfield1/load_a_field Error: pyro - /obj/explosion/pyrosolver2/dopnet1/pyro_solver/add_turbulence/add_forcvel_temp_to_vel: OpenCL Exception: clEnqueueUnMapMemObject (-30).... WTF? Quote Link to comment Share on other sites More sharing options...
5DNick Posted April 7, 2021 Author Share Posted April 7, 2021 this only seems to happen when attempting cache. i'm trying to troubleshoot atm Quote Link to comment Share on other sites More sharing options...
5DNick Posted April 7, 2021 Author Share Posted April 7, 2021 it maybe VRAM problem. i have 24GB on a 3090 so thought it would not be a problem but decreasing voxel size massively solved it. so i reckon makes sense its VRAM prob yh? gunna try to find sweet spot now. Quote Link to comment Share on other sites More sharing options...
