Custom Connected adjective pieces
Hello,
nice to meet you, I starting my journey with Houdini, and I really excited!
 I explore basics with attribute wrangle and also with vex, but I want to do something and still confused because I still don't know how to do it.
Please, can some expertise can look at my idea of what I want to do? I will appreciate that a lot!
Firstly I want to do some custom connected points where is a node but I want to set the points that can joint only with 3 lines (picture name: "3 LINES").
Secondly, I want to connect then with the second scattered surface but with one condition: Only to join between surface (no to connect point on the surface, meaning no adding more points on surface (picture name: "3")
And what it shouldn't look like (picture name: "2")
Thanks!
CCAP.hip
Haha Merci! There are far better houdini teacher here I'm afraid, i have been a student for 23 years :)
By the way, a more simple approach will be to use connectadjacentpieces, adjacent piece from  point with piece attribute. So if you attribute a name attribute for your separate piece, it will do something similar and more simple to understand. But there is no guarantee the connection is unique per point...
Edited by vinyvince
  • Thanks 1
