VDB Advect inside another VBD
rkoomera
Hi!
In the attached hip file there are a bunch of spheres generated using the pig head geo and connected to a solver with VDB advect. Is there a way I make these spheres grow inside the pig ahead so that when they grow to touch the surface of the pig ahead, they should just collide and deform?
I tried converting the pig head to a vdb but I think it needs to be hollow from the inside for it work.
Thank you so much for your help!
VDB_advect.hiplc
Perhaps try using VDB Convert From Polygons on the pighead and set your VDB Combine to "SDF Intersection" instead.
Having said that, if you are looking for the effect of small balloons, this is something Vellum should handle easily and convincingly, search for the "pressure" threads on here or check the SideFX Masterclasses on Vellum for examples (and I'm sure google will show plenty more videos)
  • Thanks 1
