Flip question- Narrow Band and Reseed
isah_voodoo
Hello,
I understand that Narrow band is meant to represent a deep tank without having to generate those particles at all times. For example a whale breaching the surface would definitely use Narrow Band. What about a boat sinking ? Would that still use Narrow Band?
I am also a little confused on when to use the Reseed parameters in the flip solver. Should this generally always be on ? Is the reseeding directly correlated with narrow band ? If Narrow band is off should I still be reseeding ? Any insight would be greatly appreciated
Thank you
