Flakked Posted April 22, 2021 Share Posted April 22, 2021 (edited) Hiya, So, I have a simple HDA with an int parameter I created called weldSeamsID, and an imported Houdini Engine attrib called hemax_matid. What I'm trying to do is take that parameter, and reference it in a group SOP based on the hemax_matid attrib. Essentially, I want the Base Group to be: "@hemax_matid" EQUALS "whatever the weldSeamsID parameter is set to." I tried linking the two together via the drag and drop under the Channels tab in the HDA, but unfortunately I cannot add any extra code to that reference without it breaking. (As far as I can tell, at least.) Edited April 22, 2021 by Flakked solved Quote Link to comment Share on other sites More sharing options...
Flakked Posted April 22, 2021 Author Share Posted April 22, 2021 ended up solving this with a simple if statement: Quote Link to comment Share on other sites More sharing options...
