pfistar Posted April 30, 2021 Share Posted April 30, 2021 (edited) Greetings all! I need to align an object to a point (without using Copy SOPs). I found a short tutorial on this that uses a VOP SOP with "Align" and "Extract XForm" nodes. This works exactly as I'd like it to, but I need to rebuild it as it was created in Houdini NC, and is also a few years old so it appears some of the nodes have been deprecated. I did my rebuild approximating the original file with non-deprecated nodes, however, I'm not getting the normal-to-rotation alignment I need and I'm at a loss for where to look to resolve this. Attached are screenshots, one derived from original file (Non-commercial), the other is my re-build (Indie). The results in the Geometry Spreadsheet tell the story. Respective .hipnc and .hiplc files are also attached. Preemptive thank to any responders! NpF N_to_angle_NonCommercial.hipncFetching info... N_to_angle_Indie.hiplcFetching info... Edited May 1, 2021 by pfistar Quote Link to comment Share on other sites More sharing options...
