HDK - Custom File Chooser
We are moving to URL based filepath's using a custom Asset Resolver in Solaris.
I would like to implement a custom file chooser across the entire Houdini session that could return a URL type from a selection.
  • I can see you can toggle between OS and Houdini in your prefs.
  • I can see some File System classes like FS_InfoHelper can work with the value in the parm.
Would I need to to extend the File parm template type? Is this even possible? Is there something in HOM that could do this?
Any thoughts appreciated.
Cheers,
Aaron.
