calling the vex help card on demand on a wrangle node
demoan666
while writing a line of vex function in a parameter field, the help card appears every time you drop down a "comma" or end "quote marks" for the next item on the function.
However this behavior doesn't occur while writing the same function inside an attribute wrangle node, it appears only once after dropping down the first parenthesis and to call it again i have to go to the beginning (right after the first parenthesis) - press space and then back-space
is it possible to get the help card on demand inside the Attribute wrangle window (i am not asking about the F1 help/ docs call) OR the same behavior as we get in the parameter window? - very helpful for vex-noobs
thanks plenty in advance!
d.
Edited by demoan666
