rkoomera Posted June 8, 2021 Share Posted June 8, 2021 Hi! Is there a way I can connect two points to form an edge? I made this short screen recording showing how this can be done in blender. https://share.getcloudapp.com/4gunmPOn I think the poly split node should be used to achieve this. But the process takes way too long and the bevel does not create a circle. I'm sure there's a better way to do this. This is a screen recording of me trying to do the same in Houdini - https://share.getcloudapp.com/4gunmP6k Thank you! Quote Link to comment Share on other sites More sharing options...
Fenolis Posted June 9, 2021 Share Posted June 9, 2021 Is it possible for you to record with something like OBS and process through https://ezgif.com/maker or just provide screenshots with annotation arrows pointing for emphasis? These links are quite terrible. Quote Link to comment Share on other sites More sharing options...
rkoomera Posted June 9, 2021 Author Share Posted June 9, 2021 @Fenolis here are the gifs. Quote Link to comment Share on other sites More sharing options...
Fenolis Posted June 9, 2021 Share Posted June 9, 2021 @konstantin magnus has a tutorial that relates to the particular task of creating holes from points - you may be able to adapt this method to suit your needs. Personally, I would suggest selecting the faces around the point, using a PolyExtrude with a small inset and scale the front face to 0, and fusing the close points together. Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted June 9, 2021 Share Posted June 9, 2021 Thank you @Fenolis, but nowadays I would rather suggest using the circle from edges-node. Here's a procedure for dynamically adding holes on a parametric surface: holes.hipnc 2 Quote Link to comment Share on other sites More sharing options...
rkoomera Posted June 9, 2021 Author Share Posted June 9, 2021 awesome! thank you for your help!! Quote Link to comment Share on other sites More sharing options...
