Point normals with Vertex normals
PeteNics
Hi.
I'm trying to get my head around requiring both point normals with vertex normals in a HDA. I'd like to have vertex normals so I can get some sharp edges on geometry created in Houdini but also need to use point normals so I can orientate instances correctly. When I combine the two, the latter of the merge takes priority and I look the normal information (E.g. merging the point normals then the vertex normals, causes a loss of the point normals).
60c1f96b2b2d8_PointnormalandVertexnormal.thumb.png.d9bebb38c8aa5eb1535ac83cd0271375.png
Is there a way round this? can the instancing use another attribute on the points to set the rotation of the instances correctly?
I managed to work around this. My fix was to use vertex normals for the generated geometry and covert the @N to @orient before merging the instancing point with the geo.
The Vex for the wrangle looks like:
matrix3 m = maketransform(@N,@up);
@orient = quaternion(m);
Which came from the article on here Convert_N_and_Up_to_Orient
