andrejklimov Posted June 15, 2021 Share Posted June 15, 2021 Good Afternoon All, I have few points that for some reason jumping around. Is there a way to keep the animation and maintain point numbers in the same order, for Rivet to move other geometries? Any suggestion will be greatly appreciated. Points.abc Quote Link to comment Share on other sites More sharing options...
Alexdezh Posted June 15, 2021 Share Posted June 15, 2021 I guess you can extract the first frame from your alembic and animate it by transferring @P from the rest of the sequence. Quote Link to comment Share on other sites More sharing options...
andrejklimov Posted June 16, 2021 Author Share Posted June 16, 2021 Thank you, Yes that what I had in mind, but my Vex experience is not there yet in order to copy transformation from the nearest point. Or transfer transformation matrix. Or am I overthinking it? Who can show the approach? Quote Link to comment Share on other sites More sharing options...
Alexdezh Posted June 16, 2021 Share Posted June 16, 2021 You can use a custom solver with Attribute Transfer node inside. Here is my take on the problem: Point stabilization.hipnc I decreased alembic fps to 15. There are some jittery motions at 25 fps. I'm not sure if it was intended or it's just artifacts. 1 Quote Link to comment Share on other sites More sharing options...
andrejklimov Posted June 17, 2021 Author Share Posted June 17, 2021 Simple but brilliant, thank you. Completely forgot the power of the solver. Quote Link to comment Share on other sites More sharing options...
