Instance to points Solaris
Hello guys
I want to scatter geometry, using name attribute.
I've made it work in index attribute. Its just assign 0,1,2... as integer then the instace read those index attribute.
While in name attribute it need to write anstring attribute on points relating to the prototype name. tried a few ways to write that but it still not giving the same result as index one.
please help me.
thanks in advance
ps: i will upload an .hip file of this exemple.
solaris_instance_byname_v00.hipFetching info...
  • 9 months later...
Hi gangland
It was just a matter of changing the point names to "flower_A" without the slash, but since you're using the Stage Manager the prototype name ends up needing the "FLORES" when you use `lopinputprims('.', 1)` as the instancer Prototype Primitives, so you'd also need to put "/FLORES/flower_B /FLORES/flower_C /FLORES/flower_A" there without the quotes.
Same thing with your Collection, you only needed to pick the primitives instead of leaving `lopinputprims('.', 0)` there.
I've attached a file, and Thanks for yours. I'm just studying LOPs Instances and it was quite useful.
solaris_instance_byname_v01_ED.hiplc
