s0updev Posted July 13, 2021 Share Posted July 13, 2021 (edited) This is probably a dumb question but I'm trying to follow a course to learn Houdini and I'm stuck. I can't get an attribute with Bind node in Attribvop, the attribute I am trying to get is a vertex attribute, I can get the P attr though which is a point attribute. Geometry is imported alembic with vertex maps but it doesn't matter I guess And I have one more question. Seems like the Bind Export node creates points attributes, but in the video I'm trying to follow it creates vertex attributes. So am I missing something, Is it just a difference in houdini versions? Or can you choose what attribute to create? tutor-cubes.hip Edited July 13, 2021 by s0updev Quote Link to comment Share on other sites More sharing options...
s0updev Posted July 14, 2021 Author Share Posted July 14, 2021 I got it, AttribVOP run on Points instead of Vertices Quote Link to comment Share on other sites More sharing options...
davpe Posted July 15, 2021 Share Posted July 15, 2021 On 14. 7. 2021 at 8:57 AM, s0updev said: I got it, AttribVOP run on Points instead of Vertices AttribVOP can run over any elements you tell it to (there is a "Run Over" dropdown menu on the VOP node). You can also bring different element attributes using import_Detail_Attribute_VOP / import_Primitive_Attribute_VOP / Import_Point_Attribute_VOP / import_vertex_attribute_VOP. i.e. using this you can bring vertex attribute into point VOP, for example. Quote Link to comment Share on other sites More sharing options...
