VEX - Using a point attribute from an array in a foreach loop
Hello everyone,
this is my first post on this forum so thank you for welcoming me and please be indulgent if I'm not posting on the correct channel.
I've been trying to wrap my head around an issue that I'm facing with VEX for a couple of days but I'm really stuck.
My goal was to iterate through each points of a input and to create a Polyline between two points if there are close enough from each other
Problem is that if point 1 is close from point 6, it will create a Polyline (so far, so good) but when my VEX script reach point 6, the invert is also true. So VEX will create a second line from point#6 to point#1...
I'm trying to add some line in my script to raise a flag if a point has already been "activated" (used if you prefer) to use that as a check before creating anything.
From my understanding VEX scripts are running on each points sequentially so I tried to create an attribute called "active" that I can raise to 1 every time this point has been going through my script.
When I'm trying to get my attribute "active" from my foreach loop, it returns 0 if "active" has been initialized on the same VEX wrangle node but it's returning the right value if it has been set in a previous node.
What am I missing here ?
Thanks
float radius = chf('radius');
int ptArray[] = nearpoints(0,@P,radius, 2);
@active = set(1);
i[]@array = ptArray;
    foreach(int pointNum; ptArray)
        int activated = point(geoself(),'active',pointNum);
        printf("activated = {%g}", activated);
        if(pointNum != @ptnum && activated != 1){
            int line = addprim(0,"polyline");
            addvertex(0, line, @ptnum);
            addvertex(0, line, pointNum);
            setpointattrib(0,"active",pointNum,1,"set");
That's a good idea @Fenolis that I followed and I find this wrangle SOP into "Connect Adjacent Pieces"
The part that is interesting for me seems to be located at the end under this last condition.
Quote
    // Don't create connections to multiple points on the same piece, or
    // to other points on our piece.
    // Only search in the direction of the point normal.
    if (s@__piecename != other_piecename && dot(other_P - @P, @N) >= 0)
I'm not really interested by the check for the normal direction but more about the first part of the condition when they are checking if s@__piecename != other_piecename. The problem is that there is no variable s@__piecename define in the script prior to this line.
What does this formulation mean ?
Thanks
The full VEX script:
float search_radius = chf("../searchradius");
int max_pts = chi("../maxsearchpoints");
int max_connections = chi("../maxconnections");
string piece_attrib = chs("../pieceattrib");
int use_cluster = chi("../useclusterattrib");
string cluster_attrib = chs("../clusterattrib");
int cluster_attribtype = -1;
int my_cluster_i;
string my_cluster_s;
if (use_cluster)
    cluster_attribtype = pointattribtype(0, cluster_attrib);
    if (cluster_attribtype == 2)
        my_cluster_s = point(0, cluster_attrib, @ptnum);
    else
        my_cluster_i = point(0, cluster_attrib, @ptnum);
string known_pieces[];
int num_connections = 0;
for (int other_pt : nearpoints(0, @P, search_radius, max_pts))
    if (use_cluster)
            string other_cluster = point(0, cluster_attrib, other_pt);
            if (my_cluster_s == other_cluster)
                continue;
        else
            int other_cluster = point(0, cluster_attrib, other_pt);
            if (my_cluster_i == other_cluster)
                continue;
    string other_piecename = point(0, piece_attrib, other_pt);
    vector other_P = point(0, "P", other_pt);
        if (find(known_pieces, other_piecename) < 0)
            int other_anchor = point(0, "__anchorpt", other_pt);
            addprim(0, "polyline", i@__anchorpt, other_anchor);
            ++num_connections;
            if (num_connections >= max_connections)
                break;
            append(known_pieces, other_piecename);
There is a Switch-If upstream that tries to initialize the __piecename attribute on points - you may have to initialize this properly using a Connectivity SOP/Attribute Wrangle to see how it flows.
s@__piecename is shorthand - what it's doing is looking for a string @ttribute on the incoming points called __piecename, to be compared with other_piecename. If such an attribute is not found, it returns a result of 0.
51 minutes ago, animatrix said:
When you create polylines, you can check if the current point number is greater than the target point number, or the opposite to avoid duplicates:
if ( @ptnum > targetpt )
    addprim()
Elegance.
