Anand
Hi, I have been using the RBD material fracture node just to create a simple glass shatter effect in Houdini (v18.5.462). Whenever I reopen the file I am getting "Load warnings and There are either Synchronizing child node" or "Skipping unrecognized parameter" node error". Nothing has changed between when I have created the file and reopened it. Not sure why is it happening. Does anyone has any clue about this?
Warning:     Problem while synchronizing child node:
             Warning:     Skipping unrecognized parameter "searchradius".
             Skipping unrecognized parameter "usetags".
    [/obj/Fracture/rbdmaterialfracture1/CONCRETE_FRACTURE0/primary]
Warning:     Skipping unrecognized parameter "vexsnippet".
             Skipping unrecognized parameter "vex_strict".
             Skipping unrecognized parameter "vex_exportlist".
    [/obj/Fracture/rbdmaterialfracture1/CONCRETE_FRACTURE0/volumenoise]
    [/obj/Fracture/rbdmaterialfracture1/CONCRETE_FRACTURE0/noisedscatter1/volumevop2]
Warning:     Skipping unrecognized parameter "depthmethod".
    [/obj/Fracture/rbdmaterialfracture1/CONCRETE_FRACTURE0/rbdinteriordetail]
Warning:     Skipping unrecognized parameter "external".
    [/obj/Fracture/rbdmaterialfracture1/CONCRETE_FRACTURE0/chipping/rbdrewireconstraints1]
    [/obj/Fracture/rbdmaterialfracture2/CONCRETE_FRACTURE0/primary]
    [/obj/Fracture/rbdmaterialfracture2/CONCRETE_FRACTURE0/volumenoise]
    [/obj/Fracture/rbdmaterialfracture2/CONCRETE_FRACTURE0/noisedscatter1/volumevop2]
    [/obj/Fracture/rbdmaterialfracture2/CONCRETE_FRACTURE0/rbdinteriordetail]
    [/obj/Fracture/rbdmaterialfracture2/CONCRETE_FRACTURE0/chipping/rbdrewireconstraints1]
    [/obj/Fracture_wood/rbdmaterialfracture2/CONCRETE_FRACTURE0/primary]
    [/obj/Fracture_wood/rbdmaterialfracture2/CONCRETE_FRACTURE0/volumenoise]
    [/obj/Fracture_wood/rbdmaterialfracture2/CONCRETE_FRACTURE0/noisedscatter1/volumevop2]
    [/obj/Fracture_wood/rbdmaterialfracture2/CONCRETE_FRACTURE0/rbdinteriordetail]
    [/obj/Fracture_wood/rbdmaterialfracture2/CONCRETE_FRACTURE0/chipping/rbdrewireconstraints1]
