Flip broad splash
gangland
Hello guys,
i have an object falling into water, by default the collision seems dull and weak.
i trying to pull water around the object by using an pop then converting into vell field then bring it dynamically to flip again.
i not sure if i'm approaching the situation efficiently, does anyone have an good solution?
i will post my dynamic rnd, its seems dull yet.
broad_splash.hip
7 hours ago, CeeGee said:
Some of your settings are bit strange, maybe you want to use them like that not sure.
But i did some cleanup and tweaks to your initial tank, to use narrowband and adaptive solve to make it faster so you can push more details.
broad_splash_02.hip
Cool, i will take a look at file.  ill return afterward
Hey man, your file is working outstding. those small tweaks has add a lot to the effect. also the usege of narrowband, it saved a huge amount of time, file and ram.
Thanks to share this valuable knowledge with the community. i owe you a beer
Edited by gangland
