Openport, Python And Win32
rdg
Hello again,
I now try to get into houdini and picked a project.
A lot of my projects depend on external data and I am now trying to get my external data into houdini.
I guess there are a lot of ways to do this.
I got the pythontohoudini-bridge working and already set some flags of objects with python. [1]
This lead me to a lot of questions:
Can I use this technique to "poll" data from python every frame and change properties over time?
If I execute openport -r "python myScript.py" 12000 in the textport the console tells me "Error running python" - where can I set the paths for houdini to look for external programs?
Can I put 'openport -r "python myScript.py" 12000' in a channel ? I guess not, as this script cannot return a value ...
Should this be triggered at frame change?
I even thought about encoding my textfiles as images and read them with chops (?) but I can not find ord/chr functions inside houdini to return the numbers to letters.
My question should be:
How can I read data from external files, that are not images, hips or the like?
thank you for your patience,
Georg
[1] http://odforce.net/wiki/index.php/PythonTo...ni#Introduction
What kind of data are you trying to read in?
You can read in data with chops, using a file chop. Raw data can be read in simply my making a file with the .chan extension on it. Every row in the file is treated as a frame and each column is a channel.
This data can then be passed to anywhere else in Houdini you like.
Edited by sibarrick
sibarrik,
thank you.
This helps alot and I will try this right now.
I want to parse a xml file.
I have a python script that returns ie. random chunks of tags. (Or you add arguments to the command line to have control over the picking of the chunks).
So I want houdini to call the script every frame and get some answer back.
Thats what I thought I need to do :rolleyes:
Georg
That might be a bit more tricky. Chan files read data for an entire frame range at once.
You might want to check out the unix sop.....
Is this for a realtime thing? or can you parse everything first and then create a data file that houdini can read.
i must admit I'm still a little hazy about what you are trying to achieve.
  Quote
me, too.
I am trying to wrap my head around the concepts of data-flow.
I have a long list of strings (names).
I want to use this strings in various context of houdini.
Sure I should shuffle the strings and write a textfile.
That way I can concentrate on more obvious problems :)
Georg
