how to edit preset in houdini
The easiest way is to just select the preset so that all the parameters are set to the preset values, delete the preset, change your values, and save as a new preset with the same name. You can also look into your nodes presets files in Documents\{houdini_version}\presets\Sop but they are saved as .idx and not easy to work with.
