TouchDesigner True Begginer's Question
tansuisan
Hello guys, this is the best portal with professionals and content i've ever seen in the Houdini community. Actually my main topic is about with another node based design program, TouchDesigner. I'll be glad if you can help me.
I'm trying to create a point fluid animation that we can easily do in Houdini on TouchDesigner. In Houidi, as you know, the "Point to Value" -> "Attribute from Map" method is working just fine. However i coudnt fine the solution how to do it in TouchDesigner. I wanna create that scene and activate it with a trigger or sensor camera like Kinect.
https://rb.gy/90gn8i
So far, i have been able to create a triggerable geometric node via particleGPU and textured with a image.
https://rb.gy/4oc9ci
Thank you guys!
Edited by tansuisan
