AustinW Posted October 17, 2021 Share Posted October 17, 2021 Thanks in advance for the help! I'm advecting a vdb so it grows over time. Once turned back into polygons, I'm hoping to stick UV's on it. The setup - I promote my uv's to point attribute and in the initial "VDB from polygons" I created a new surface attribute to store the uvs - I advect both vdb volumes in a sop solver, and then convert the vdb to polygons. - I then use an "attribute from volume" node to transfer the uv's from the volume onto the mesh. This works for the first frame, but as expected distorts and breaks down pretty quickly as the volume grows. I've researched and found examples of using the "dual rest fields" option in the Pyro and Flip Solver and then blending between the two rest states to "reset" the texture distortion as the mesh grows. There is a great example of this by Jesper Rahlff here (https://forums.odforce.net/topic/49461-lava-flow-question/?do=findComment&comment=227475). Great! I can create a rest field but... - What exactly is rest2? how is it different from rest1? - And how would I go about setting it up here without using the pyro or flip solver? If you have a better way to achieve this always open to that too VDB_Advect_UV_rnd_v02.hiplc Quote Link to comment Share on other sites More sharing options...
