UpyopyoSky Posted October 27, 2021 Share Posted October 27, 2021 I am learning python, and found hou.setPreference is very useful. However, I cannot find what exact names and values we can write in hou.setPreference(XXX,XX). Do we have that info/list in sidefx document pages? So far, I only found some in odForce, not from sidefx: hou.setPreference("general.autosaveinterval.val", "15") hou.setPreference("general.autosaveinc.val", "2") hou.appendSessionModuleSource('''hou.hscript("autosave on")''') Or ideally Sidefx implements a feature that houdini can monitor what a user change parameters in UI, and automatically generate python code in python window? (I know we can drag and drop a parameter to python winodw to generate parm's path, but more convinient way ^^.) Quote Link to comment Share on other sites More sharing options...
JXS Posted October 28, 2021 Share Posted October 28, 2021 Hi! Yes. I recall helping out sometime last year on a similar topic. To get the list of names and values, you can run the following quick snippet on a Python shell: list_of_prefs = sorted(hou.getPreferenceNames()) for pref in list_of_prefs: print(pref + ": " + hou.getPreference(pref)) Basically, hou.getPreferenceNames() will return a tuple of all the preference names (the names you would use in setPreference). the sorted function is optional. In a loop, you can process each name to get its current value using hou.getPreference(). 1 Quote Link to comment Share on other sites More sharing options...
UpyopyoSky Posted November 1, 2021 Author Share Posted November 1, 2021 Jael, That's perfect!, thanks! ! SideFX should write it on that document. Just in case, I am pasting all the commands here for everyone.: networkeditor.TopInOutColorTag_15: networkeditor.TopInOutColorTag_16: networkeditor.TopInOutColorTag_17: networkeditor.TopInOutColorTag_18: networkeditor.TopInOutColorTag_19: networkeditor.TopInOutColorTag_2: networkeditor.TopInOutColorTag_3: networkeditor.TopInOutColorTag_4: networkeditor.TopInOutColorTag_5: networkeditor.TopInOutColorTag_6: networkeditor.TopInOutColorTag_7: networkeditor.TopInOutColorTag_8: networkeditor.TopInOutColorTag_9: networkeditor.TopInOutColor_0: networkeditor.TopInOutColor_1: networkeditor.TopInOutColor_10: networkeditor.TopInOutColor_11: networkeditor.TopInOutColor_12: networkeditor.TopInOutColor_13: networkeditor.TopInOutColor_14: networkeditor.TopInOutColor_15: networkeditor.TopInOutColor_16: networkeditor.TopInOutColor_17: networkeditor.TopInOutColor_18: networkeditor.TopInOutColor_19: networkeditor.TopInOutColor_2: networkeditor.TopInOutColor_3: networkeditor.TopInOutColor_4: networkeditor.TopInOutColor_5: networkeditor.TopInOutColor_6: networkeditor.TopInOutColor_7: networkeditor.TopInOutColor_8: networkeditor.TopInOutColor_9: networkeditor.allowdiveintohdas: 1 networkeditor.allowdroponwire: 1 networkeditor.autoscroll: 1 networkeditor.badge64bit: normal networkeditor.badgechilderror: large networkeditor.badgecomment: normal networkeditor.badgeconstraints: normal networkeditor.badgedynamictop: normal networkeditor.badgeerror: large networkeditor.badgehastakedata: hide networkeditor.badgehdalocked: normal networkeditor.badgehdaunlocked: normal networkeditor.badgekinematics: hide networkeditor.badgelopdebug: normal networkeditor.badgeloppopulationmask: normal networkeditor.badgelopunloadedpayloads: normal networkeditor.badgemessage: normal networkeditor.badgeneedscook: hide networkeditor.badgenodehasdata: hide networkeditor.badgenodelocked: normal networkeditor.badgenodeunload: normal networkeditor.badgenotcompilable: hide networkeditor.badgetimedep: normal networkeditor.badgevexcache: normal networkeditor.badgewarning: normal networkeditor.connectorsnapradius: 0.700000 networkeditor.copypathstoclipboard: 1 networkeditor.dimunusednodes: 0 networkeditor.distancefordrag: 0.050000 networkeditor.doautomovenodes: 1 networkeditor.dosnapping: 1 networkeditor.flagsallowpreselect: 1 networkeditor.gridsnapping: 1 networkeditor.maxflyoutscale: 10000.000000 networkeditor.maxnameheight: 0.000000 networkeditor.maxnamewidth: 10000.000000 networkeditor.maxtaskgraphrows: 20 networkeditor.maxworkitemsperrow: 10 networkeditor.minnameheight: 0.000000 networkeditor.shakesensitivity: 1.000000 networkeditor.showanimations: 1 networkeditor.showcancelledworkitems: 1 networkeditor.showcookedworkitems: 1 networkeditor.showcookingworkitems: 1 networkeditor.showdirtyworkitems: 1 networkeditor.showfailedworkitems: 1 networkeditor.showloplayercolor: 1 networkeditor.shownodeshapes: 1 networkeditor.shownodetypes: 1 networkeditor.showpartitionworkitems: 1 networkeditor.showpreviews: 1 networkeditor.showprompttext: 1 networkeditor.showsimpleshape: 0 networkeditor.showstackedlook: 1 networkeditor.showstaticworkitems: 1 networkeditor.showtaskgraph: 1 networkeditor.showvopinoutlabels: 0 networkeditor.snapradius: 0.100000 networkeditor.solohighlightedworkitems: 0 networkeditor.taskgraphlimitrows: 1 networkeditor.textbadgecomment: truncated networkeditor.textbadgecontextoptiondeps: selected_full networkeditor.textbadgedescriptiveparm: truncated networkeditor.textbadgedetailid: hide networkeditor.textbadgelayercount: truncated networkeditor.textbadgeloplastmodifiedprim: truncated networkeditor.textbadgeoutputforview: truncated networkeditor.transientinfo: 1 networkeditor.wirefadefactor: 1.000000 notify.echohotkey: 1 notify.echohotkey.val: 1 notify.errors.location: 0 notify.helptip.location: 0 notify.helptip.menu: 0 notify.location.menu: 0 notify.timelimit.duration: 5 notify.timelimit.enable: 1 notify.timelimit.val: 5 notify.timelimited.val: 1 objcache.clear.val: objcache.memory.val: Always objcache.memory.val: Always objcache.memorylimit.val: 153600 objcache.memorylimit.val: 153600 objects.folderflipping.val: 1 objects.folderflipping.val: 1 objects.highlight.val: 1 objects.highlight.val: 1 objects.keepPos.val: 2 objects.keepPos.val: 2 objects.keepPosMoving.val: 2 objects.keepPosMoving.val: 2 objects.kinoverride.val: 0 objects.kinoverride.val: 0 objects.linkchanneleditor.val: 1 objects.linkchanneleditor.val: 1 objects.linkchopviewer.val: 0 objects.linkchopviewer.val: 0 objects.openchanneleditor.val: 1 objects.openchanneleditor.val: 1 objects.overwriteanim.val: 0 objects.overwriteanim.val: 0 objects.pickingmenu.val: 0 objects.pickingmenu.val: 0 objects.selectsubnet.val: 0 objects.selectsubnet.val: 0 objsop.switch.val: offsetzoomdefault.val: 1 ok.val: oldtumble.val: 3 open.val: openShell: openState: 1 orientation.val: Y Up parmdialog.embedviseditor.val: 1 parmdialog.embedviseditor.val: 1 perfmon.rampprefs.val: 0 0.45 0.82 0.08 1 0 0.4 0.9 0.45 0 1 0 0.75 0.8 0 0 1 0 pl.pathbehaviour.val: 0 pl.showAll.val: 0 pl.showHidden.val: 0 playbar: point_percent.val: project.history.menu: 0 radial_edit.act: radial_pin.val: 0 radialmenu.val: 24 radials_manage.act: ramp_color_schemes.val: 0 render.activerenderers.val: Mantra render.edit.menu: 0 render.preview.menu: 0 render.showallrops.val: 1 render.showallrops.val: 1 render.start.menu: 0 rendererListVscroll: resmgr.autosave.desk.val: 0 resmgr.pathbehaviour.val: 0 resmgr.showall.val: 0 resmgr.showhidden.val: 0 save.asset.menu: 0 saveastype.menu: 0 saveviewcmds.val: 2 scripting.exprlanguage: hscript scripting.exprlanguage.menu: hscript scrollstyle.val: 0 selector.areaselvisible.val: 0 selector.areaselvisible.val: 0 selector.fullloops.val: 0 selector.fullloops.val: 0 selector.geopickdistance.val: 5 selector.geopickdistance.val: 5 selector.useexisting.val: 1 selector.useexisting.val: 1 sendAnonymousStats: 0 setpivottumbledefault.val: 1 shelf: showCurrentSimMenu.val: 1 showmenu.val: 1 side_help.val: 0 simcreatenew.val: simenable.val: 1 simenabletoggle.val: simresetlist.menu: 0 smoothLines: 1 smoothlines.val: 1 sopcache.level.val: 1 sopcache.level.val: 1 sopcache.memory.val: Never sopcache.memory.val: Never sopcache.memorylimit.val: 1024 sopcache.memorylimit.val: 1024 sopcache.unload.val: Flag sopcache.unload.val: Flag sopstates.exportcookselectiontype.val: 0 sopstates.exportcookselectiontype.val: 0 startupPage: 0 states.bones.autoenablecplane.val: 0 states.bones.autoenablecplane.val: 0 states.curve.autoenablecplane.val: 0 states.curve.autoenablecplane.val: 0 states.objcurve.autoenablecplane.val: 0 states.objcurve.autoenablecplane.val: 0 states.path.autoenablecplane.val: 0 states.path.autoenablecplane.val: 0 status: Successfully loaded toolBox_v083_dateStamp.hip statusbar: take.autoincludeassets.val: 0 take.autoincludeassets.val: 0 takecreate.val: takemenu.val: 0 tiles.perfstats.val: 1 tiles.perfstats.val: 1 timeStampToAskAboutAnonymousStats: -1 toggleSideHelp.val: tools.createincontext.val: 0 tools.createincontext.val: 0 tools.maxhistory.val: 6 tools.maxhistory.val: 6 tools.opnamespacefilter.val: 1 tools.opnamespacefilter.val: 1 tools.secure.val: 1 tools.secure.val: 1 tools.sopviewmode.val: 1 tools.sopviewmode.val: 1 trees.displayicons.val: 1 trees.displayiconsbydefault.val: 1 ui.bright.val: 1 ui.contrast.val: 1 ui.editor.paren: 1 ui.editor.paren: 1 ui.editor.syntax: 1 ui.editor.syntax: 1 ui.editor.toolbar: 1 ui.editor.toolbar: 1 ui.gamma.val: 1 ui.parm.external: 0 ui.parm.external: 0 ui.parm.help: 1 ui.parm.help: 1 ui.parm.paren: 1 ui.parm.paren: 1 ui.parm.syntax: 1 ui.parm.syntax: 1 ui.saturation.val: 1 ui.textport.help: 1 ui.textport.help: 1 ui.textport.paren: 1 ui.textport.paren: 1 ui.textport.syntax: 1 ui.textport.syntax: 1 undo.menu: 0 undomemlimit.val: 100000 unlock.asset.menu: 0 up.val: updatemode.menu: 0 viewport.allowadaptivesubd.val: 1 viewport.altkeyviewcontrols.val: 1 viewport.autosetviewpivotonselection.val: 0 viewport.defaulthoming.val: 0 viewport.delayinactive.val: 0 viewport.directeddollydefault.val: 1 viewport.lightpasscolorbuffertype.val: 0 viewport.locatecomponents.val: 1 viewport.offsetzoomdefault.val: 1 viewport.oldtumble.val: 3 viewport.orientation.val: Y Up viewport.scrollstyle.val: 0 viewport.setpivottumbledefault.val: 1 viewport.wire_toggle.menu: Wireframe viewport.wiretoggle.val: Wireframe Ghost wiretoggle.val: Wireframe Ghost 1 Quote Link to comment Share on other sites More sharing options...
