Scale UV Island Only Without Layout
Hello!
I'm trying to use the UV Layout SOP to set the correct scale of all my UVs relative to 3D space - Although I don't want to change the position of the UVs with the layout mode. I only want to make use of the UV Layout SOP's ability to set this correct relative scale. Is this even possible?
I guess I want to make use of the auto layout, but without the layout part if that makes sense?
