katosa Posted December 17, 2021 Share Posted December 17, 2021 (edited) Grouping by bounding objects(this time its polywire) has unexpected result at the crossing point of polywire mesh. Green mark point is the whear I suppose I can get as group. How could I get the point ? Thank you. P Edited December 17, 2021 by katosa Quote Link to comment Share on other sites More sharing options...
Kvale Posted December 20, 2021 Share Posted December 20, 2021 My guess is the mesh you're using to group your points with is canceling each other out, because they are overlapping. If you instead convert the polyvire geometry to a vdb and do group points by bounding volume instead of bounding object, it should work. 1 Quote Link to comment Share on other sites More sharing options...
katosa Posted December 21, 2021 Author Share Posted December 21, 2021 thank you very much. I could do by converting polygon to vdb. Quote Link to comment Share on other sites More sharing options...
