Thin Light VOPnet
danteA
So after much work (because I've never used VOPs before :), I finally managed to convert the thin.vfl code by Jason from the odforce shaders into a VOPnet. I only had to cheat a bit on the lighting model part using an inline VOP for that and also to use PI. Am I the only one who can't find how to put down the PI constant down in VOPs?
So here's attached the palette file for it. To use it, you will have to navigate to the file via the Shader Palette. You can then drag & drop it into SHOPs. This will also create the corresponding VOPnet as well.
Thanks Jason for creating it!
dante
thinlight.zip
