Best fitting skin for a set of closed curves
AntoineSfx
I have this set of closed curves, all of them have the same point count. (Those are cross sections of a leg of SimpleFemale)
How do I make the skin nice and even ?
A useful operator  is Reverse SOP / Shift / U Offset , to rewire the prims so that they connect differently ot each others in skin
I'm trying so see if I can abuse another operator with built-in minimization
Any idea ?
Using FindShortestPath, I built one path that links the top primitive to the bottom one, and in a foor loop, I shifted the vertices of the primitives so that  the first vertex  is always the one on that path.
It is not necessary the global minimum, as the top and bottom are chosen by the user, but it's good enough for simple cases.
