highSierra Posted January 24, 2022 Share Posted January 24, 2022 Hi, I'm working with houdini crowds and I'm looking for a way to trigger a transition based on clip percentage. I can see there a "current state duration" trigger type, but I would like it to be based on the percentage amount of the clip animation length. For instance, if I have a 30-frame animation clip, trigger a transition when the clip has reached it's 30th frame (or 100%). The length of the clips might vary, which is why I'm not just using "current state duration" set to 30 Frames. Any help is appreciated! thank you! Quote Link to comment Share on other sites More sharing options...
