Opdigits In Channel References
kubabuk
Hi guys, I need some help with the following expression. I'd like to create channel reference between testmantra2 and testmantra1 and have access to the value of the end frame. But instead retyping this each time I add a new ROP, I'd like to make use out of opdigits.
so for example testmantra2 is referencing testmantra1:
ch("../testmantra"`(opdigits(".")-1)`"/f2")
------to be clear opdigits returns me (2) -> 2-1->1------
But the problem is the whole expression seems to be to complex to work.
I was thinking about strcat but I have three elements to concatenate:
"../testmantra"
`(opdigits(".")-1)`
"/f2"
and strcat joins only two...:(
does it make sense?
thanks
kuba
