madebygeoff Posted February 9, 2022 Share Posted February 9, 2022 Anyone know of a simple way to set a bunch of instances to each use the same image sequence as a texture, but with each instance offset by a certain number of frames. You can't promote the file path in the RS texture node, so I can't use local overrides. The best I've been able to do is set a bunch of individual textures each accessing the images sequence offset a little bit in time. Then use a point wrangle to write out different shop_material paths for each instance. It works, but creates a boatload of shader VOPs. But I can't think of how to do it in a single shader VOP. Quote Link to comment Share on other sites More sharing options...
madebygeoff Posted February 10, 2022 Author Share Posted February 10, 2022 So the solution is the good old stylesheet. -- First edit the parameter interface on the RS material builder VOP and drag the filename field from the texture node inside the VOP into the interface, effectively promoting that file path field so it is exposed on the VOP. -- Then add a new stylesheet and style to your object -- Add a target: point instances -- Add a condition: Point name or path attribbute: value=* -- Add an override: Set material type=Material override path=/mat/path_to_your_shader_VOP -- Add an override script: type=Material Parameter Override name=the name of the parameter you promoted above (tex0 by default) Override type=Attribute binding Value=myFilePath Then add an attribCreate node to your SOP chain for the packed objects Make a string attribute myFilePath and set it to whatever file path you want complete with any expressions to offset the frame numbers per point instance. For instance: /path/to/my/image/sequence/myImgSeq.`padzero(4, $F + ($PT*10))`.exr Offsets each instance by 10 frames. 1 Quote Link to comment Share on other sites More sharing options...
