Detect the frame which a point is added to a group and exist for only that frame
NoaX
I have a line a point that is animated, and over time they are added inside a group based on criteria. I'd like to store the frame at which the point is first added to the group, and delete this point. store_frame.thumb.PNG.e27ddb4a7785bdc2983e504acbdef799.PNG
It seems so simple, and frankly embarrassing I can't solve easily - I have tried solvers or perhaps hardcode an age to the points.. but no luck!
delete.hiplcFetching info...
Edited by NoaX
Hey Nelson,
I attached a hip file showing how you could store the frame at which each point is being added to the "delete" group. I'm not sure I understand why you wish to store the frames but also at the same time delete the points once they get added to the group. If the points are deleted then the attribute used to store the frame will be gone too haha.
Apologies if I mis-understood!
  On 2/28/2022 at 11:54 PM, Ziyad said:
Hey Nelson,
Expand
Taking a look! And thank you,
The idea is to copy for example a sphere to each point, but have the sphere exist for only one frame so that I might use it to emit RBD
