Filecache with attribute name
To fetch an attribute from geometry in HSCRIPT, you can use the various point(), prim(), detail() functions.
Note that the syntax is different from their VEX counterparts.
Also, and this is important for you, you need to use a different function for string attributes. points(), prims(), details(). (it reads as : point string, prim string, detail string)
So, for you, this would be the code
`prims(0, 0, "name")`.bgeo.sc // primString(input 0, primitive 0, attribute "name")
ok thanks for your help :)
