Double-click .hip to load correct redshift version
Hi guys, I wrote .bat files to run different Houdini that tied with different redshift core data path.
The .bat files run fine as my houdini.env is HOUDINI_PATH =  ;$REDSHIFT_COREDATAPATH/Plugins/Houdini/${HOUDINI_VERSION};&" However, if I double click on a .hip file, redshift is not loaded as it is run by hview instead of the .bat, is there a way to have it to load redshift?
Edited by zjie
