jamesearnest244 Posted April 17, 2022 Share Posted April 17, 2022 (edited) Hi, I have a model that renders fine unfractured, but once I've fractured it, I get shading artifcats from bad normals. It looks like Houdini is inferring normals for the new vertices by interpolating between neighboring ones, but it's not looking right. I've tried using an Attribute Transfer SOP to take the normals from the pre-fractured model, and it helps a little but doesn't solve it completely. Also tried the cupsing settings on the Facet SOP and Vertex SOP. I'm stuck. Does anyone have an idea how to fix this? I'm not doing any fancy fracturing, just the RBD Material Fracture node. Thanks! Edited April 17, 2022 by jamesearnest244 Quote Link to comment Share on other sites More sharing options...
Whatsinaname Posted April 20, 2022 Share Posted April 20, 2022 I would try and do the fracturing myself, either using boolean fracturing or Voronoi fracture and see if it helps. The RBD Material Fracture is a high-level node that does many different operations inside, but your geo might be a bit special, so it won't work in your specific case. Voronoi Fracture and Boolean fracture do have some options regarding the treatment of normals. Alternatively, you can try creating new normals for the geo before fracturing, maybe those new normals are in a better spot for RBD Material Fracture to work straight out of the box. Quote Link to comment Share on other sites More sharing options...
jamesearnest244 Posted April 27, 2022 Author Share Posted April 27, 2022 Thanks, but I get the same issue when fracturing manually with the Voronoi Fracture node. Quote Link to comment Share on other sites More sharing options...
