Return Item name of ordered Menu
freko12
Hi, I have been struggling with this for the past 2 days.
I need help in returning the name of the selected item in an ordered menu.
What I am trying to achieve is to dynamically populate the ordered menu with the list of projects via menu scrip (python)
import os
path="k:/Projects/"
dirList = os.listdir(path)
dirs = []
for dirName in dirList:
    fullPath = os.path.normpath(os.path.join(path, dirName))
    if os.path.isdir(fullPath):
          #dirs += [fullPath, dirName]
          dirs += [dirName, dirName]
return dirs
This code scans for folders in directory(k:/Projects/) and lists them in the menu. All works fine till here.
Now I need to return the name value of the selected menu item from another parameter.
So I have tried this
listItemName = hou.pwd().parm("parmList_Projects").eval()
and this
listItemName =  hou.pwd().parm("parmList_Projects").evalAsString()
but it returns only integer values from (0,1,2,...)
How can I get the name or label value ?
Edited by freko12
3 hours ago, Stalkerx777 said:
It's easier to use a String type parameter (with a menu) for this instead of ordered menu. This way, eval() will return a string.
Wow it worked like a charm. How come I overlooked this!
Thanks a ton Stalkerx777
Cheers!
