anicg Posted April 26, 2022 Share Posted April 26, 2022 Attached hip file. The Seed under Ocean Spectrum seems to be doing much more than just the seed that I'm used to in Houdini, which is giving a different look of the same, if you see what I mean. Wave height and sharpness are controlled by wind parameters (Speed and Chop), but the seed seems to be messing with the sharpness, sometimes the height the waves. Here is an example with seed 0, and the seed 56, ceteris paribus, where the difference in sharpness is glaringly obvious. Why does the seed impact areas (e.g. Shaprness) that other parameters are supposed to control? ocean_spectrum_seed.hiplc Quote Link to comment Share on other sites More sharing options...
