Ptransform()
ivan
ptransform() does not have correct help browser information.
How is it used?
Is there a function that returns the matrix of a particular space?
I assume there is, and that's what would return the 4X4 that ptransform needs...
matrix WT = otransform("WORLD");
vector Pw = ptransform(P,WT);
you need an object called "WORLD" for this to work...
How is it used?
How is it used?
Hi Ivan,
Yup, the help is wrong. Or rather, it may be correct for H9, but certainly not for H8 (assuming I can believe what a little bird told me :))
You're basically stuck with
matrix otransform(string path_to_obj)
Usually the string argument is a null object with "Output transform as render space" toggled ON (in the Render tab of the null).... *and* displayed when rendering, else it won't make it to the ifd.
But the good news is that we may FINALLY have a predefined world space (and others) in H9. Unfortunately it's not something they can back-port to H8.
