Hdk Vray
Hi Everybody....
There is a strange problem I am facing while creating VRAY procedure.
My VRAY code takes two inputs. A source Geometry and a Template
Geometry.
And copies source geometry on each point of template geometry. It is
same as Copy SOP but only a VRAY procedure.
Inside the code, I am using "queryObject" and "queryGeometry" to get
pointer to gdp.
Here sgdp is Source_Geometry and tgdp is Template_Geometry.
The code is like,
for(i=0;i<tgdp->points().entries();i++)
ppt = tgdp->points()(i);
gdp->clearAndDestroy();
gdp->merge(*(GU_Detail *)sgdp);
xform.identity();
xform.translate(ppt->getPos().x(),ppt->getPos().y(),ppt->getPos().z());
gdp->transform(xform);
final_gdp->merge(*(GU_Detail *)gdp);
And I am using final_gdp as the output.
Now the thing is, The code compiles normally and renders properly when
my camera is somewhere near to the template object. As my Camera moves
around,
the x,y,z values of template points sometimes show correct values and
renders properly and sometimes the values are wrong and doesn't render
the object(or may be the object moves out of screen because of the
values)..I checked it using console.
I don't know why the values are changing as my template object is
static.
What is the problem with getPos. According to my knowledge it returns
the world position, so the camera position should not matter.
----iamjaideep80
Jaideep Khadilkar
TD, Sciclone Motion Graphics
HI......
Is the problem related to LOD parameter passed to render function. Because LOD is the only parameter that changed as the camera changes. I commented all code that was modyfying anything and only checked the point pos x,y,z for my Template Geometry. But still it is changing as I change my camera. The problem is with getPos function. Thats for sure. Is LOD affecting the getPos function. I am not using lod in my code anywhere...
----iamjaideep80
Jaideep Khadilkar
