bentraje Posted June 1, 2022 Share Posted June 1, 2022 Hi, While selecting Guide Groom Node in 18.5, executing the code below gives me a value. node.parm('selectionnode') But when I execute that in 19. It gives me a None. This breaks the whole script. So I was wondering if there are any API changes in 19 that I should use instead of the 'selectionnode' P.S. For reference, I'm trying to make this script Houdini 19 compatible. Quote Link to comment Share on other sites More sharing options...
bentraje Posted June 1, 2022 Author Share Posted June 1, 2022 The script above relies on the selection node. as you can see below, H19 no longer uses the selection node (i..e it does not appear in the parameter). By any chance, any one knows the H19 equivalent of selection node? Quote Link to comment Share on other sites More sharing options...
