ykcosmo Posted March 2, 2007 Share Posted March 2, 2007 when I use copy to stamp Geo,it works fine, but the input nodes of copy is yellow, and warn me ues stamp instead of param? Quote Link to comment Share on other sites More sharing options...
aracid Posted March 2, 2007 Share Posted March 2, 2007 when I use copy to stamp Geo,it works fine, but the input nodes of copy is yellow, and warn me ues stamp instead of param? because param is being replaced by stamp, so i think they trying to discourage you from using old expressions. Quote Link to comment Share on other sites More sharing options...
stevenong Posted March 2, 2007 Share Posted March 2, 2007 Yep, param() might go away in a new version so you should use stamp() in case your hip file breaks. Cheers! steven Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted March 2, 2007 Share Posted March 2, 2007 The param() was there long before any HDA related tool set was implemented. Trouble with param() is that it can potentially force another sop chain that contained the same param() to cook. So it's getting deprecated soon. stamp() is much newer (as of v7?) and solved the issues that param() has, and works much better in the HDA environment. Quote Link to comment Share on other sites More sharing options...
ykcosmo Posted March 6, 2007 Author Share Posted March 6, 2007 oh, I don't know about this....though I have used houdni from 5.0 to now.... Quote Link to comment Share on other sites More sharing options...
