Ugo9p1 Posted June 7, 2022 Share Posted June 7, 2022 Hi, i made a symbiote like setup after following a course using a find the shortest path node in a loop guided by attribute paints to mark the start of where the curves should grow out of and an end point where they should go and stop i then used a polywire to make the curves a bit more 3d and then vdb mesh that to get a more fluid and goo like look. My question is how could i make this setup more interesting looking and more accurate to something like spider-man 3 (not the whole thing just the covering of the mesh part) right now it's flowing along the surfaces of the mesh, we're in my case i would like for the curves to wrap around the mesh like hands or tentacles but still be flowing with a vdb in the end. Kinda like this exemple made by Liang Chaopo : https://www.bilibili.com/video/BV1Yi4y1G7Sx/ but with bigger curves and possibly guided like mine is already in a way i could cover the entire mesh or an area if i desire. i tried doing a similar setup using pops but couldn't figure out how to get a flowing looks like the setup i have now in the first place. What should i use ? Should i restart from scratch and using vellum or is it doable with my setup right now ? Here's a link to what my setup look like right now in motion : https://youtu.be/4WNrDwG7XkE Also if any freelancers are reading and feel like they could do this let me know i would gladly hire someone to help me if i can afford it. Thanks for Reading Quote Link to comment Share on other sites More sharing options...
