pighead Posted June 8, 2022 Share Posted June 8, 2022 Hi, I'd like to create a library of RedShift materials across multiple projects. There must be a smarter way than re-building stuff all over again and again. Thanks Quote Link to comment Share on other sites More sharing options...
PixelNinja Posted June 13, 2022 Share Posted June 13, 2022 You can build what's called a "Gallery". Once you've made a shader you like select it, right-click and click "Save to Gallery". From then on your shader should show up in the tool palette. Doesn't have to be a shader either; any node or group of nodes can be stored in a gallery. Quote Link to comment Share on other sites More sharing options...
