mrakgr Posted June 13, 2022 Share Posted June 13, 2022 The building generator SOPs are lightly documented and don't even show up in interactive help. The tutorial videos are out of date at this time. The Labs Building Generator Utility has an option to add optional variation name and weight. It has been a while since I used Houdini, but as far as I can tell the modular pieces in the building generator SOP don't work like in the scatter nodes. The Labs Building Generator node only seems to be using the name attribute, and putting in the extra variation instead does not seem to have any effect. Is it possible to vary the wall pieces separately from the floor overload mechanism? My hunch is that variations are intended for this, but I do not know how. Quote Link to comment Share on other sites More sharing options...
jfiola Posted October 19, 2022 Share Posted October 19, 2022 Variations seem to work by using the Module Names from other Building Generator Utility nodes. Quote Link to comment Share on other sites More sharing options...
