Is There Any Sop Can Scan Volume Point?
ykcosmo
I am not sure exactly what you mean by "scan volume point", but if you want to fill a volume with points then you can bring your geo into POPs and for the source, select volume. Just make sure that your geometry is manifolded. It needs to be closed or else you will get points outside your geo.
