ASUS TUF A15 upgrade question
NickTsimpetonidis
Hi all,
I would much appreciate your advice with the following.
I am thinking to start a Houdini course after September, and unfortunately at the moment I cannot afford to buy a new workstation. So I will be using my current laptop, ASUS TUF a15 which has:
Ryzen 4800H, 16GB RAM, 500GB m.2 drive and RTX2060 GPU.  The laptop has two m.2 slots. So I will be upgrading the ram to 64GB (maximum supported), and adding a second m.2 hard drive  for files, cache etc. I am puzzled about the capacity of the second drive. Would 2TB be enough or I should go with more?
Any other advice would be much appreciated
Just to let you know that apart from the future Houdini course (and hopefully work), I am doing video editing in DaVinci and compositing in Fusion if that matters/affects any decision for upgrade.
Many thanks!
Kind regards,
Nick
